Author Topic: Everything I touch turns to sh!t and trash!!  (Read 3924 times)
Offline Helios_Blue_Valver
« on: 12 November 2003, 18:36 »
What a week. First the wifes car breaks down and I have to listen to her moan and complain about it until I fix it. Then I go out to my Golf to go to work and It won't start. Ran fine yesterday when I parked it. But today just refused to do anything but crank over on the starter. After 15 minutes and holding the throttle to the floor I finally convinced it to start. Runs excellent, no problems once it started. Drove to work and left it sit while there and the same thing. I am thinking warm up regulator (i think that is what it's called) has crapped out on it. This could also explain why it seems to be over fueling lately. Am I on the right path here anyone. It is an 89 16v. Thanks in advance
Offline Dizzie
  • Make friends with your fast
Re:Everything I touch turns to sh!t and trash!!
« Reply #1 on: 12 November 2003, 18:40 »
my '87 8v had a similar problem. It'd start fine when warm, even sometimes when it was cold, but after I'd left it parked at work for 8 hours it'd turn over loads before firing up. I cleaned out the intake and I think that helped a bit aswell as changing the air filter.
golfvr6
« Reply #2 on: 12 November 2003, 18:55 »
Have a look at the cold start valve(5th injector) and the thermotime switch. This briefly enriches the mixture when starting.
Offline tinman
« Reply #3 on: 12 November 2003, 20:01 »
Or your distributor maybe on its way out....
now its getting cold you need a decent spark to start the engine. It'll run fine once its started but it might a be a combination of wear from this year and the weather finally dampens the spark sufficiently to stop it starting.
Tin
Offline Grovit
« Reply #4 on: 12 November 2003, 20:04 »
My Mk II was a nightmare to start in the cold - highly intollerant of either cold or damp conditions - As T/M suggests it may be the dizzie - although as always with these things it's a bit of a process of elimination excercise:
Distributor / leads / plugs blah blah blah ..........
Chris
I went to a seafood disco last week...and pulled a muscle.
golfvr6
« Reply #5 on: 12 November 2003, 20:16 »
If there is a problem with the dizzie, then its likely to be the hall sender.
« Reply #6 on: 12 November 2003, 20:51 »
Golfvr6, is the cold start valve sort of below and forward of the dizzie on the same side of the block with a fuel line running to the metering block on top of the air box and from there to the fifth injector? I think I may be thinking the same part but calling it a different name. I am thinking that is the problem as I have to hold it to the floor to make it start cold and it smells of petrol very strong after starting. I'll have a go with that first and then start on the rest. I have it booked in for service next week anyway but I hate having anything wrong with my car if you know what I mean. :) I'll let everyone know how it works out.
golfvr6
« Reply #7 on: 12 November 2003, 20:58 »
The cold start valve is on the end of the inlet manifold, gearbox end. Have you checked for a spark ?
Offline Dizzie
« Reply #8 on: 12 November 2003, 21:24 »
stop saying my name god dam it! ;D
love you really  :-*
golfvr6
« Reply #9 on: 12 November 2003, 22:10 »
love you too  :-*
