Author Topic: ...didnt work...  (Read 1359 times)
Offline Chugadub
...didnt work...
« on: 14 January 2006, 17:49 »
well, i spent this morning bypassing the bypass valve with some copper tube, and then flushed out the whole coolant system till it was spangly clean. an then got all the air out of it.
an it still dosnt work!
i dont know what else it could be now, my heaters are really poor, looking round the site ive tried flushing system, the valve and the thermostat is fine (i think).  :undecided:
anyone got any other ideas?
 :smiley:
Cant afford a sig.....
Offline steviem
Re: ...didnt work...
« Reply #1 on: 14 January 2006, 17:53 »
Could it be the matrix?
I really should get mine done, but am waiting till march to do a full dash/heater swap from a mk3/mk4 or polo or corrado
Offline Mr Blue
« Reply #2 on: 14 January 2006, 17:55 »
run the engine with the water cap off till the radiator fan kicks in
should bubble like a b!tch :smiley:
now...take off a heater matrix pipe so allllll of the air comes out. Once the water flows nicely then it should be sorted.
make sure someone fills the coolant bottle while you do this :smiley:
Offline ...joe
« Reply #3 on: 14 January 2006, 18:57 »
also make sure the heater slider is on 'hot' when you run it up as this seems to help prevent air locks...
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Chugadub
« Reply #4 on: 14 January 2006, 20:14 »
thanks guys
yeah i had sliders on full, and i did run it untill it boiled an fan kicked in, but if anything its worse now!  :sad:
Mr.Blue why is taking matyrix pipe off gonna help me? thats the only bit i dint do?
Offline Mr Blue
« Reply #5 on: 14 January 2006, 22:43 »
gets the air locks out quicker. There are two pipes going to the matrix. loosen one/take it off till the water flows nicely. Thats why u need an extra hand to topup the water level.
Now shutup and dowit
« Last Edit: 14 January 2006, 22:45 by Mr Blue »
Offline Chugadub
« Reply #6 on: 14 January 2006, 23:44 »
spose i'll do it then...but im gonna wait untill the morning now... :smiley:
Offline dubninja
« Reply #7 on: 15 January 2006, 10:02 »
Will be interested to know if that works for you, as my heater has been pants since i did the headgasket on the motor. Tried just about everything except the above!.
