Author Topic: Oil just disapears  (Read 4023 times)
golfvr6
Re:Oil just disapears
« Reply #10 on: 12 November 2003, 20:15 »
Yep i agree with you Tin. Its all a question of how much and how often. I also agree that Vws stated 1 litre per 1000 miles is a bit iffy.
Offline Ant
« Reply #11 on: 12 November 2003, 22:59 »
1 litre per 1000 miles, didn't the GTi was 2-stroke ;)
Offline modulater
« Reply #12 on: 13 November 2003, 21:05 »
It all depends on the service history of the car as well, If its been lovingly looked after its less likely to go burning oil. As said all engines will burn oil, its unavoidable, but the case here sounds excessive.
Get someone to follow you up the road and see when the smoke is coming out of the exhaust, you wont notice it half the time as your looking at the road ahead I hope and not constantly in your rear view mirror.
With that much oil being lost it must be going somewhere.
Blue MK2
« Reply #13 on: 13 November 2003, 21:20 »
Mines a oilaholic too but not that bad. Check under the sump if there is a build up of oil. Maybe the oil you are using is too thin?
Offline gti power
« Reply #14 on: 14 November 2003, 03:33 »
thanks guys
