Author Topic: Oil just disapears  (Read 4022 times)
Offline gti power
Oil just disapears
« on: 12 November 2003, 05:48 »
Hy!
I wonder if anyone can help, I have a MK2 golf gti 8v 1992 K reg, which has done about 140,000 miles.
The problem is that when I look at the oil level it always reads lower than half way on the dipstick. I keep on toping it up and within two weeks the oil disapears to the bottom of the dipstick again.
The car runs good, good power, been serviced,no smoke comes out of the exaust, no oil leaks underneath the car nothing.The only thing is that next to the ht leads there seems to be a bit of oil.
Can anyone tell me wher my oil is going??
Any help would be really good
thanks.
golfvr6
Re:Oil just disapears
« Reply #1 on: 12 November 2003, 10:39 »
Probably worn valve stem oil seals, if you are only losing a bit of oil its nothing to worry about. VW quoted using 1 litre of oil per 1000 miles to be acceptable. How much oil are you using per 1000 miles?
Offline tinman
« Reply #2 on: 12 November 2003, 12:05 »
this is to cover themselves - so they invent this bullsh*t.
my last car (fiat bravo) rarely burnt any oil, the nissan from s2n did 3k miles without burning a drop. but my mates c5 (piece of turd) was guzzling a frightening amount of oil - they just pointed him to the manual as their disclaimer....
Tin
« Last Edit: 12 November 2003, 13:01 by tinman »
Offline mk28vpb91
« Reply #3 on: 12 November 2003, 12:52 »
Does it matter how many miles you do or does the oil just go down the same amount every two weeks? If it's the leaking through valve seals or past piston rings then doing a lot of miles would push up the consumption.
Offline tinman
« Reply #4 on: 12 November 2003, 13:02 »
oil shouldnt really go any where. the engine is a sealed unit at the end of the day.
if its going somewhere, its either leaking or being burnt. it doesn't evaporate. If its leaking - theres a hole and a patch under the car - if its being burnt - then something in the engine is worn.
Tin
Blue MK2
« Reply #5 on: 12 November 2003, 13:51 »
Hang on a minute...........
Can you get K reg MK2 golfs anyone?
Offline Slim Shady
  • Thrash her like a ginger step child
« Reply #6 on: 12 November 2003, 13:55 »
K is possible, i've seen a couple - it'd be a later reg'd 1992 model.
What oil do you use?  Fully Synthetic (eg mobil 1) isn't really recomended in older vehicles.
« Last Edit: 12 November 2003, 13:56 by Slim Shady »
Offline Golfgal
« Reply #7 on: 12 November 2003, 16:28 »
check to see if theres any oil under sump.
V5 Beetle owner. I'm just here for the misfire threads....
golfvr6
« Reply #8 on: 12 November 2003, 19:01 »
Every engine will drink some oil, the idea that an engine is a completely sealed unit isn't strictly true. For example the valve stem oil seals will commonly leak a bit of oil when cold, as the engine warms up the rubber seals expand hence seal better. How much oil an engine uses does depend on the individual unit itself.
Offline tinman
« Reply #9 on: 12 November 2003, 20:12 »
point taken, what i was trying to say is that a good engine doesn't guzzle its way through oil.
Tin
