Author Topic: Service reset HELP !  (Read 1879 times)
Offline APS
« on: 13 January 2006, 15:31 »
 :sad:
Hi all, just spent 35mins and several attempts at this reset procedure with no success whatsover
1. Push and hold the odometer button.
2. Turn on ignition.
3. Turn digital clock button clockwise.
4. Turn off ignition.
done this and when the ignition is turned back on its still displaying " service int" !!
anyone have any other advice ?
am i missing something ?
thanks in advance
Tony
Golf MK4 1.8T
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: Service reset HELP !
« Reply #1 on: 13 January 2006, 16:36 »
This procedure should work, ma :undecided: :undecided:y take a few attempts tho
Offline Phil_M
« Reply #2 on: 13 January 2006, 17:45 »
when you twist the clock adjust button to the right hoid it there till service now disapears.
GOLF 1.9T AGU TD05H 18G
http://smg.photobucket.com/albums/v218/pipmann30/GOLF%20GTI%20%20TURBO/?albumview=slideshow
Front wheel drive monster 0-60mph in under 5sec 0-100mph in 10sec
Offline APS
« Reply #3 on: 13 January 2006, 18:52 »
hi all ... when i turn the clock adjust clockwise the display does change between "oil service"
and  " ----"
but when i then turn off the ignition it reverts back to " service int "   :undecided:
really begining to  :lipsrsealed: me off !
regards
Golf MK4 1.8T
Offline Browny
  • AUG Power
« Reply #4 on: 26 January 2006, 12:21 »
Mines doing same mate, any other advice would be greatly received as patience is wearing thin, but i aint paying £150 for a reset tool
Browny
Hey baby how u doin?
Offline GazB
Offline richandhazel
« Reply #6 on: 29 January 2006, 11:14 »
If there are a number of services overdue, you may have to do it a few times to clear them all.
When you turn the ignition on, do you then release the odometer button and then turn the clock adjust or do you keep the odometer button pressed?
Offline APS
« Reply #7 on: 30 January 2006, 11:01 »
Hi , yeah tried a few times with different combinations .... soon as the ignitions turned back on ... then release ... and tried holding in for a further 2/3 seconds also.. then turned the clock adjust .... it then goes to :   ---- then to the oil service again ... but once ive switched off then on again ... it reverts back to service int   :undecided:
i maybe need a few more attempts ... already doen it maybe 7 or 8 times ..
thanks again
Golf MK4 1.8T
