Author Topic: how to fit fse power boost valve  (Read 6675 times)
Offline nosaj26
« on: 12 January 2006, 19:34 »
the title says it all, any body know where i can get a guide or help?
Offline daz123
Re: how to fit fse power boost valve
« Reply #1 on: 12 January 2006, 22:20 »
msn search shoiuld find one
Offline Mk3Tim
« Reply #2 on: 13 January 2006, 14:48 »
Has anyone actually used one of these on their cars?  If so can you actually notice any difference at all?
Offline Len
« Reply #3 on: 13 January 2006, 15:13 »
It tells you on the box how to do it!!!! Unless you got it second hand. (without box)
I got one on my other car (Peugeot 405 Mi 16) and its dead easy to fit! Just secure it then change a few fuel lines around.
Yes it does make a difference, but more in the driveablity of the car rather than extra power. It makes the car more throttle responsive.
www.sas.org.uk
www.the-ace.org.uk
Offline Overseer
« Reply #4 on: 13 January 2006, 16:46 »
this is a proper thing.. and not to be confused with the "allegedly" crappy ecotek power boost valve..
Offline Len
« Reply #5 on: 13 January 2006, 16:56 »
Heard a few views about it, the blurb says it acts as a non return valve (the return pipe to the tank) so that the relief pressure is raised.
A mechanic friend told me that all they do is boost the fuel pressure.
Either way it can only be a good thing!
www.sas.org.uk
www.the-ace.org.uk
Offline nosaj26
« Reply #6 on: 13 January 2006, 19:36 »
it comes with instructions but there just sh!t (for someone who knows very little about engines)
Offline Len
« Reply #7 on: 16 January 2006, 13:01 »
You just need to find a suitable place to secure the valve (it should have a bracket in the box), then take off the fuel lines and connect it the way they tell you too! Dead simple!
www.sas.org.uk
www.the-ace.org.uk
Offline nosaj26
« Reply #8 on: 16 January 2006, 13:11 »
im gonna have to give it go
Offline bonsaiburton53
« Reply #9 on: 22 January 2006, 18:44 »
It is simple just remove the fuel regulator at the end of the fuel rail( left side of fuel rail if your looking at the engine) and replace it with the adaptor plate then just plum in the hoses. The valve won't fit a 1994 golf or below you need to adapt it.
