Author Topic: Blue smoke on start up?  (Read 2162 times)
Offline Pobby2005
« on: 11 January 2006, 16:16 »
Hello all, I'm after more help... I've started to get blue smoke from the exhaust when I start up from cold. Is this likely to be Valve Stem Oil Seals? If so it it a big job?
Marc
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: Blue smoke on start up?
« Reply #1 on: 11 January 2006, 19:48 »
What model is it?
Offline charri42
« Reply #2 on: 11 January 2006, 23:41 »
Engines gerenally shouldn't burn oil. Could well be valve stem oil seals as it is obviously slowly 'seeping' in to the combustion chamber overnight - then quickly being burnt off.
I wouldn't do anything unless it is using masses of oil, it simply isn't economical to do so. Lots of cars smoke a little on start up and I am sure there is no performance issue (unless it is really bad), just a bit embarassing if you cover passers by in smoke!
I have had loads of old cars that do this, its when it smokes when it is hot that the engine is getting really tired. Having the work done (£Â£Ã‚£Ã‚£Ã‚£) save you from a bigger bill in the future.
