Author Topic: first day, first problem, doh  (Read 1777 times)
Offline fastrhino
« on: 09 January 2006, 20:27 »
wel i have discovered my first problem requiring attention, at speeds above 40 mpr there is a whining coming form the rear of the car could this be bearings or brakes?     :cry:
Offline Stu-1.8T
  • Quit your Jibba Jabba
Re: first day, first problem, doh
« Reply #1 on: 09 January 2006, 20:49 »
Jack it up at the back, take hold of the bottom and top of the wheel and see if it wobbles in and out. If it does, usually means the bearings knackered.
Offline Bazzer
« Reply #2 on: 09 January 2006, 21:17 »
probably bearings... usually you can hear it get louder and quieter when you go round medium fast sweeping bends...
If you've ever owned a renault 19 you'll know how to diagnose which bearing it is by the steering wheel!!  :grin:
Bazzer
Offline fastrhino
« Reply #3 on: 09 January 2006, 21:40 »
yeah it does seem to get louder and quieter when you go round corners and eccelerate, the noise was less noticable on the motorway cruising at 70, and was still appahrent when you coast with the clutch pressed in
Offline vwagain
« Reply #4 on: 09 January 2006, 21:45 »
Probably just needs regreasing and nipping up a little. Both my rear ones needed it when i first got mine.  The front ones are the non adjustable dry, pressed in type,  and yes, one of mine needs doing. !!!!
Stu
1996 2.0l 8v, black magic pearl paint<br />
Offline adyh
« Reply #5 on: 10 January 2006, 10:51 »
Erm , did you not take it for a test drive ?
Offline fastrhino
« Reply #6 on: 10 January 2006, 17:16 »
Erm, yes i did, i took it for a blast but the noise was not appahrent, it was only driven for about ten minutes around a residential area, so i guess i should of insisted on a longer run to stretch her legs a bit more. the noise comes and goes depending on speed.
i have not had time to check, but i feel sure it is the rear wheel bearings that are suspect.
Offline adyh
« Reply #7 on: 11 January 2006, 09:47 »
If it is the bearings they arent that hard to do on the back at all .
Haynes give it a 3 Spanner Rating
