Author Topic: Problem with throttle revving  (Read 5425 times)
Offline Davo13
« on: 10 November 2003, 21:54 »
Can anyone help?
I've got a mk2 Golf Gti 1.8 8v.  The problem is it some times revs on it's own.  Someone suggested that it's the throttle valve switch that sits on top of the throttle.  Has anyone experienced this before and what can be done about it and if needed were and how much will the part cost.
Any guidance appreciated
Blue MK2
Re:Problem with throttle revving
« Reply #1 on: 11 November 2003, 09:58 »
Is your car tuned right? I think the throttle switch is for letting the ECU know that the car is on full throttle.
Mine revs up and down around the 1000-Rev mark. GTi's have an automatic choke to keep the car idle i think
« Last Edit: 11 November 2003, 09:58 by Blue MK2 »
golfvr6
« Reply #2 on: 11 November 2003, 10:41 »
Which engine is it? digifant or k-jet?
Offline richandhazel
Offline Davo13
« Reply #4 on: 11 November 2003, 18:18 »
Hey there,
It's a digifant. very strange it only does it sometimes and it usually does it for 5- 10 mins sometimes not even that and then it will stop.
cheers
golfvr6
« Reply #5 on: 11 November 2003, 18:22 »
Maybe a problem with the idle stabilisation valve, also as a suggestion maybe get the car on a fault code reader. What does the car drive like?
Offline Davo13
« Reply #6 on: 11 November 2003, 21:58 »
Cheers for all the pointers so far everyone, much apreciated.
The car drives like new mate sweet as.  It's only done 57000 miles.
« Last Edit: 11 November 2003, 21:59 by Davo13 »
Offline roon
« Reply #7 on: 11 November 2003, 22:11 »
What's the difference between digifant and k-jet and how do you know which one you have  ???
golfvr6
« Reply #8 on: 11 November 2003, 22:15 »
K-jets have a fuel distributor(like spaghetti junction) on top of the airbox, digifants don't, they have a fuel rail.
Offline roon
« Reply #9 on: 11 November 2003, 22:31 »
why did they bother to have two types?
