Author Topic: stalk  (Read 1122 times)
Offline j5.gti
stalk
« on: 07 January 2006, 14:33 »
hi all my  stalk is not workin. iv got mk3 do thay fit and work many thanks :wink:
ave it!
Offline Gambit
Re: stalk
« Reply #1 on: 07 January 2006, 17:15 »
is your car a late spec golf? i.e. hazard switch on the steering column surround? if yes then its a straight swap
if not then you need another pre 89 stalk
Re: stalk
« Reply #2 on: 08 January 2006, 11:39 »
To make them fit you swap the hazard switch and the plastic trim on the front of the indicator stalk over from your old stalks.  Once you take them off it will be obvious what needs to be done :)
