Author Topic: HELP - Hand brake light stays on all time  (Read 5799 times)
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« on: 06 January 2006, 13:10 »
My hand brake light (right hand side of steering wheel) stays on when I put the hand brake down in my black cab - only started to do it the last week... not done any work on it - so not sure why its started.
What I have done so far to troubleshoot.
1. I've checked the switch itself with another one - all fine.
2. I've taken the one cable off the hand brake switch - good connection and switch itself is fine as well.
Could this be a earth issue?
Anyone had this issue before and how to fit?
thanks Si
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Judderi
Re: HELP - Hand brake light stays on all time
« Reply #1 on: 06 January 2006, 13:15 »
As far as i know the wire or switch on the handbrake lever is just an earth wire. Usually its just a dodgy switch but i think you say you have already checked that. The wire might have worn down to the wire somewhere and be touching bare metal thus making an earth. Try the lever and light ends 1st before you go ripping y car apart mate.  :grin:
Offline Madone_si
« Reply #2 on: 06 January 2006, 13:56 »
Yeah I think that is the case too - will have to folllow the cables and find that broken part. cheers mate.
Another job to add to the on going list..... will it ever stop?!  :grin:
SOLD - BLACK SOY 92
Judderi
« Reply #3 on: 06 January 2006, 14:01 »
I think the easy answer to that is NO. But we all love tinkering at the end of the day. If we didnt we would buy a new car and use it to get from a to b.  :grin:
P.S shoot me if that ever happens.
Offline golfpro
  • If in doubt, pay someone else to do it!
« Reply #4 on: 06 January 2006, 15:35 »
my hand brake stayed on for a while in my mk3, and i later found out it was coz i was out of brake fluid. Only just god away with it in the end, luckily i avoided death somehow in a big cloud of smoke.
Not sure if this has anything to do with it but thought id share my story anyhow.
thats the best mk3 ive seen..ever! its just clean and subtle.. :cool:
Offline mk1
« Reply #5 on: 06 January 2006, 21:00 »
What he said ^^^^^^^^.
Light doubles up as a low fluid level indicator.
Steve.
Offline Madone_si
« Reply #6 on: 08 January 2006, 15:48 »
brake fuild level is a max - I'm going to have to check the cables as I think its earthing at some point alone the cables. Also I've tested the sensor in the brake fuild top cylinder and its working ok.
SOLD - BLACK SOY 92
Offline alpesh
« Reply #7 on: 09 January 2006, 13:11 »
On a MK1 the hand brake light is connected to a dual circuit.....
1st circuit: hand brake switch (located under the lever)
2nd circuit: Oil pressure switch. If the oil pressure is not right then the light will come on. I dont know if its means the oil pressure is too low or high.
Replace the pil pressure switch since these go faulty.
On some models the second circuit is the brake fluid level. So if the brake fluid is too low then the light turns on.
Offline richandhazel
« Reply #8 on: 16 January 2006, 20:34 »
Another problem that I'm sure you would have noticed can be the handbrake adjustment may be such that the lever isn't pulling down onto the switch properly. Pushing down on the lever would confirm that.
Offline Madone_si
« Reply #9 on: 16 January 2006, 21:02 »
I tried that Rich - the light isn't working at all now - will be looking at this properly at the weekend - spent this weekend completing the new suspension install - what fun that was..... NOT!
SOLD - BLACK SOY 92
