Author Topic: beam alxe :-(  (Read 2495 times)
Offline theviper
beam alxe :-(
« on: 05 January 2006, 08:50 »
off to the breaker saturday to get it and a windsreen so how easy is it ??? looks like 4 bolts break pipe and handbrake cable  and off she comes  is that about right or am i in for a surpise when doing it
if anyone in the portsmouth area wishing to help i will not stop then lol
Pete :evil:
Judderi
Re: beam alxe :-(
« Reply #1 on: 05 January 2006, 09:00 »
Ive just done a rear axle on the wifes astra. To me the setup looked very similar to that of the golf. Apart from the usual faf on with brake lines and handbrake cables on drums it was very straight forward. As easy as it looks really. Good luck!
Offline krisbattye
Re: beam alxe :-(
« Reply #2 on: 05 January 2006, 09:58 »
easiest way to take off the axle is the 3 bolts that bolt the axle plate to the bottom of the car. 17mm (if its badly rusty smack a 16mm on there)
Drop the bottom of the struts of 17mm bolt.
Disconnect the brake cables from the handbrake (in the car) cut the brake pipes (off the scrap car)
This will allow you to do all the hard work where it can easily be accessed.
Trust me this is the easiest way.  i have done 3 rear disk conversions this week.
hope this helps.
kris
WWW.Wide-Wheels.co.uk
Offline theviper
Re: beam alxe :-(
« Reply #3 on: 05 January 2006, 10:03 »
krisbattye   you dont live near portsmouth do you LOL   dose it matter if it has discs or drum's ??? what do i have to look for ?? do i need to take it of the same model ???
Pete  :evil:
Re: beam alxe :-(
« Reply #4 on: 05 January 2006, 11:47 »
If you want a windscreen, take a shaprp knife and cut the seal, its the only way to be sure you'll get it out in 1 piece :)
Offline krisbattye
Re: beam alxe :-(
« Reply #5 on: 05 January 2006, 14:06 »
Pete  :evil:
Sorry m8 i'm up in yorkshire. Lol
It doesnt matter if it is disks or drums . . just the same.
I dont think it matters if you get if from a different model. just any mk2 beam axle if it is a mk2.
Kris :cool:
Offline GTI EDITION (aka LTD)
Re: beam alxe :-(
« Reply #6 on: 05 January 2006, 14:32 »
Pete  :evil:
Kris :cool:
I believe that there is a difference between the Gti models and others .
The Gti ( and possibly the 1.8 carb) has a stiffener rod welded in to the 'V' section of the cross beam (as to how much difference it makes to the handling is another question  :undecided: )
It also may make a difference if your car has a brake pressure regulator fitted as I have a feeling that mk2 golfs/jettas without them don't have the required bracket ( where the spring is bolted) welded to the beam ( If yours has one then you'll need one with but if yours doesn't it will not matter as you can ignore it)
Hope this helps and not confuses the issue, Oli  :smiley:
« Last Edit: 05 January 2006, 14:33 by GTI EDITION »
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Re: beam alxe :-(
« Reply #7 on: 05 January 2006, 14:45 »
Only GTIs got the ARB in the rear beam, the 1.8 carb models did get a front ARB though.
If you get a GTI one you'll need GTI handbrake cables, and also faff with the brake pipes if yours didn't have a pressure regulator originally.
Offline riadh023
Re: beam alxe :-(
« Reply #8 on: 06 January 2006, 17:54 »
Hello there, Im southampton based, and basically doing the same thing as you, however just got the rear axel and just need it fitting along with my windscreen! you sure we dont own the same car!! :P Well if you get it fitted before me, let me know how easy it was. Cheers buddy
Offline Mr Blue
Re: beam alxe :-(
« Reply #9 on: 07 January 2006, 11:43 »
aint you better off getting a windscreen from insurance? 50 quid max??
The only down side is that they fit a bigger windscreen seal that looks crap   :tongue:
