Author Topic: mk2 driver brakes his?  (Read 788 times)
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
« on: 04 January 2006, 17:31 »
hi, i just picked up a mk2 85 1.6 golf n when you brake there is a hissing noise like air not fluid fron the master cylinder, if u stick ya head under the dash n brake with the engine runnin you can here it! also when u brake at idle the revs drop n it stools? i think itd the master cyilinder but there is no fluid loss? i have put a kink in the pipe fron t mainfold to the cylinder n the engine dose not cut out now but the brakes are crap n hard? the car has gti front disk n pads n a gti rear beam? if i do need to replace the master cyilider can i fit a gti one or would i need to replace th large black bell whish the sevrvo sits in, what is this by the way?
thanks for readin, any help would be grate! :smiley:
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
Offline Volkswagavin
Re: mk2 driver brakes hiss?
« Reply #1 on: 05 January 2006, 14:51 »
Sounds like the brake servo if they are hissing and need a lot of pressure to apply them.  There was another thread about dodgy servo's somewhere on this forum but I can't see it for looking!
Gav
Mk2 Golf GTI 8v - J reg
Offline gti fly bye
Re: mk2 driver brakes his?
« Reply #2 on: 05 January 2006, 22:22 »
bt servo you mean the silver part the brake lines go to? how comes the air is leakin? :sad:
