Author Topic: WHATS THIS TEMP SENSOR??  (Read 1023 times)
Offline golf gti 16valve
« on: 04 January 2006, 01:35 »
Hey ppl, ive noticed recently alot of ppl have been complaining of poor running,and have recommended changing the temperature sensor?? what is this?where does it go? and how do i know if i need one plz?? i have a 16v!
Anyhelp gr8ly appreciated   :grin:
Judderi
Re: WHATS THIS TEMP SENSOR??
« Reply #1 on: 04 January 2006, 15:05 »
are you sure they wernt talking about the 8v engine?
« Reply #2 on: 04 January 2006, 18:58 »
on the 16v there are 3 screw in ones on the right side of the block, defo worth replacing them all as they control various warm up functions :)
Offline monzablue16v
« Reply #3 on: 04 January 2006, 21:09 »
Anybody have the real life VW part numbers??
I fitted a GSF one for my dash temp gauge and it reads well high swapped with another of the three sensors and it was sat fine at bang in the middle :grrrrr:!
« Reply #4 on: 05 January 2006, 00:33 »
ETOS lists is as 049 919 501.  But if you take off one of the others give it a clean and the number will be stamped on the side :)
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #5 on: 05 January 2006, 16:15 »
gsf are about £5 each, VW are about £25 each!
Where ever you go make sure you take a multimeter with you and test each one on the omhz setting, they all need to be the same at around 900 omhz iirc
