Didnt run the engine without an ISV on - cleaned up the "new" one before I put it on.........
Running-wise at the moment, 70% of the time it runs ok. The rest of the time, when I put the clutch in the revs plummet, car tries to stall and oil light flickers on. This happens most when the car has warmed up - from cold it is quite well-behaved. With the last ISV it did that most of the time, so things have improved slightly. My guess is that this ISV is not 100% but less faulty than the last one................
Other things that I have changed to try and solve running problems are as follows: plugs, leads, filters, worn vacuum pipes, rubber bung on rocker cover, blue coolant sensor, timing has been done as well..............have I missed anything?
