Author Topic: carb cleaning kits?  (Read 2688 times)
Offline Si
Re: carb cleaning kits?
« Reply #10 on: 03 January 2006, 19:46 »
Just spray most ofd a tin into the top of the carb whilst the engine running, that will clean most if not all of the crap out of it and the engine!
If you have your heart set on stripping it make sure you have plenty of manuals so you know how to put it back together again after, the Haynes carb manual is a must :)
I tried this but it didnt clear it. Had to strip Carb down.  :angry:
I LOVE THE SOUND OF CARBS IN THE MORNING
Offline Haribo!
« Reply #11 on: 04 January 2006, 03:18 »
bollocks to it, im getting a pierburg  :cool:
Offline maximous
« Reply #12 on: 04 January 2006, 13:38 »
If you want the whole cleaning kit with gasgets then contact euro carbs in reading (just google the name) and they'll sort you out.
Offline Si
« Reply #13 on: 05 January 2006, 11:38 »
Are you sure it wasnt a 1300 you robbed the Weber from?  :undecided:
Just read your other thread "wont run prop.." and the Weber should be much better than sh!teburg!!!
Make sure its jetted for a 1600 not a 1300.  :smiley:
« Reply #14 on: 05 January 2006, 11:52 »
an old webber can be just as knackered as a pierburg ;)
Offline Haribo!
« Reply #15 on: 05 January 2006, 12:50 »
definatly jetted for the right engine, by the look of the engine i new it was either a 1600 or 1800 so i felt round the back and it was definalty a 1600, ive heard from alot of mechanics othe rpeople wiho "know about cars" and ive been assured that a pierburg running properly isnt very far of the standard of a weber anyway, pierburgs just go wrong more often and is often mistaken for being crap, but before mine went wrong it was running better than this weber. plus ive really gone off this manual choke, anyone want this weber when i get this pierburg? you can have it for 30 quid just needs stripping and cleaning out but i cant be arsed to do it,  ive had it with webers  :smiley:
« Reply #16 on: 05 January 2006, 13:49 »
how did you know it was a 1600 just by feeling round the back?  The only way to tell is to check the log book or read the engine number stamped on the front :)
Offline Haribo!
« Reply #17 on: 05 January 2006, 18:41 »
on the block right behind it just above the sump(bloody hard to reach) theres raised lettering, on my old 1800 on my old golf it read "1.8" on the automatic engine i bought for it when the 1800 blew up it had an "A", and on both my engine and the one at the scrappy it says "1.6" im just assuming that its telling me what engine it is... ???
« Reply #18 on: 05 January 2006, 22:21 »
the 1.6 carb engines didn't have 1.6 stamped on them, they had 1.8.  The blocks themselves are identical to those fitted to the 1.8 8v engines, but with a different crank & pistons to reduce the cc to 1.6 :)
Offline Haribo!
« Reply #19 on: 06 January 2006, 02:24 »
well........... what can i say......... my touchy feely skiils must be totally out of wack.... ide be no good at braile thats for sure :(, tell ya what, that solves the big mystery about my old golf and what looked like a dodgy engine conversion, foiled again
