Author Topic: tsr brakes set up or g60  (Read 1408 times)
Offline GolfGTiMk216LoveIT
« on: 01 January 2006, 17:44 »
was looking and tsr do a 280mm disk set up which would u reccomend g60 brakes or the tsr
Offline Agreeable Slick
  • Unit
Re: tsr brakes set up or g60
« Reply #1 on: 01 January 2006, 17:58 »
both 280 mm so depends on what you wanna spend your cash on.
VeeDubGTI16v
« Reply #2 on: 02 January 2006, 21:13 »
isnt it exactly the same thing :huh: by the pic on tsr,s website it looks like painted g60 brakes with black diamond discs. basically i got ate power discs, greenstuff pads and g60 callipers and carriers for about £160, slightly better than £699 tsr want
Offline shaft69
« Reply #3 on: 04 January 2006, 00:50 »
Yes same set up, Only with tsr everythings new. just get g60 set up, zimmerman cross drills and some green stuff pads. If your using bbs ra's g60 calipers dont fit use 16v ones ( they touch inner rim) :sad:
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Daz...
« Reply #4 on: 04 January 2006, 07:40 »
ive read a few things about people using 16v callipers with g60 discs but i didnt think they would fit...the g60 callipers are wider to accomodate the wider disc so surely they are what is needed with this setup? also, if im not mistaken the piston on the g60 callipers is larger than on a 16v so therefore more powerful...i may have just put a load of crap tho  :undecided:
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
VeeDubGTI16v
« Reply #5 on: 04 January 2006, 15:41 »
people who use the 16v brakes use partly worn pads so they fit in. :laugh:
Offline shaft69
« Reply #6 on: 04 January 2006, 22:43 »
What i had to do is have about 2mm taken of both pads for them to fit if using 16v calipers or yo can have 2mm taken of caliper slides, But found if you do that pads still didnt fit. Best if you have too, take 2mm of pads or as said before use some slightly worn ones.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Daz...
« Reply #7 on: 05 January 2006, 06:34 »
oohh..i had knowledge  :smug:  :grin:
