Author Topic: Headlamps wont switch off  (Read 688 times)
Offline Mr Blue
« on: 25 December 2005, 14:49 »
my headlamps wont switch off. The uprated wiring loom i made is decent and i never had this problem before until my car broke down last night
One fuse was blown and my ignition moduel was fired. the car now starts and everything works as it used to.
When i put my ignition on and switch the lights on, they wont turn off untill i pull the fuse out to reset this.
To me it sounds like a bad earth problem. Ive checked all fuses, behind the fuse box and the earth pole near the fuse box. Still cannot find a fault in any wiring. Ive even changed the headlamp relay.
Im thinking it could be the ignition switch :embarassed:
Can someone tell me what relay does what. possible to get a diagram?
chers
Blue (urgent)
« Last Edit: 25 December 2005, 14:50 by Mr Blue »
Offline Mr Blue
Re: Headlamps wont switch off
« Reply #1 on: 25 December 2005, 16:26 »
deffo not the ign switch as i pulled the connector block out and still same problem
