Author Topic: Wind noise?  (Read 2797 times)
Offline ducatimad
Wind noise?
« on: 07 November 2003, 21:16 »
Requesting help from all fellow golf gti boffins!
I hear alot of wind noise from either the top corner of the drivers door or a post - and I have checked that my window is firmly closed!
Any ideas or has someone had a similar problem or is this a golf characteristic?
hope you all can help!
Ducatimad
Offline richandhazel
Re:Wind noise?
« Reply #1 on: 07 November 2003, 22:40 »
Is the door jam adjusted correctly? Maybe the door isn't flush or being pulled in enough.
golfvr6
Re:Wind noise?
« Reply #2 on: 07 November 2003, 23:59 »
I had this on my old golf, around the top of the windows. All you can do is replace the seals.
Offline ducatimad
Re:Wind noise?
« Reply #3 on: 08 November 2003, 13:57 »
cheers, ill try replacing the drivers door seal and see what happens
Blue MK2
Re:Wind noise?
« Reply #4 on: 08 November 2003, 14:31 »
Could be that the window is not fully closing?
Offline ducatimad
Re:Wind noise?
« Reply #5 on: 08 November 2003, 14:36 »
I checked the window several times and am satified it is closing fully
golfvr6
Re:Wind noise?
« Reply #6 on: 09 November 2003, 22:22 »
The problem i had was the window seals rather than the door seals. Depends how bad it is.
Offline Slim Shady
  • Thrash her like a ginger step child
Re:Wind noise?
« Reply #7 on: 10 November 2003, 10:37 »
mk2's are renowned for noisy door seals.
replace them
