Golf mk2
What is this part?
Topic: What is this part? (Read 769 times)
psenior1
What is this part?
22 December 2005, 20:11 »
Having bought myself another GTI (86 8v K-Jet) after many years, I found another air leak (fifth so far!) - It's the t-piece plastic connector thing on the right hand side of the second pic in the link, there is a small cone connector with nothing shown on the diagram being attached to it. Whatever it was is no longer there (just a hole), I cant find anything that should be attached to it. When I put my finger over the hole the engine stalled, I had to wind the idle screw a long way out before she would even start with he hole plugged - can someone tell me what it is? Cheers...
http://volkswagen.msk.ru/vw_doc/eva2/FU01/ch5.4.html
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: What is this part?
22 December 2005, 23:47 »
You talking about the bit going to the hose labled 'vacuum line to brake vacuum booster'? If so there should be 1 vacuum line which runs off to the back of the dash clocks for the MFA, the other connections should be blanked off with caps
psenior1
23 December 2005, 01:45 »
cheers, answers my question. I was reparing the vacuum hose to et the mfa working again (which it is now) when I noticed the other hole, looks it stays plugged!
Golf mk2
What is this part?
