Author Topic: How do you hotwire the fuel pump?  (Read 1338 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 21 December 2005, 14:30 »
Going to be testing my injectors next week, and i need to hot wire the fuel pump so it on all the time with ignition on so i can raise the metering head to squirt the fuel!
I assume you do this on the relay,with a spade heads connected up, but which slots do i have to use?
Judderi
Re: How do you hotwire the fuel pump?
« Reply #1 on: 21 December 2005, 14:57 »
Offline Deefadog
« Reply #2 on: 21 December 2005, 16:31 »
Thanks mate, good stuff there!
Does not really say how to hotwire the pump though??
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 21 December 2005, 17:10 »
use a standard X contact relay instead of the standard pump one. that'll come on when the ignition is on and stay prime'ing
Mk4 Golf 150PD
Offline Deefadog
« Reply #4 on: 21 December 2005, 18:13 »
Thanks mate, is that it's actual name?
Judderi
« Reply #5 on: 22 December 2005, 08:48 »
Im sure if you remove the relay and bridge 2 of the contacts the pump will run. However i dont know which 2. Time to get y multimeter out and see whats what. Or if your one of the few people that can read wiring diagrams then have a look.
Offline Deefadog
« Reply #6 on: 22 December 2005, 11:11 »
I have had alook at the diagrams, i have no idea LoL
Yes two bridged should work, but which two? i'll blow something up knowing my luck!
If i use a multimeter, i can obviously find the ignition live coming in, but how do i find the contetction to the fuel pump? continuity test or something?
