Author Topic: Really sh!t cold starter!  (Read 891 times)
Offline Tornado
« on: 17 December 2005, 14:11 »
Hello there
As soon as the mercury drops on the old thermometer my 8v digi is very reluctant to start.
Just before it does start it turns over really slowly , just once or twice then bursts into life.
After that it starts without any problem.
Any help would be greatly appreciated
Lower!
Offline Organisys
  • Old and Slow...
Re: Really sh!t cold starter!
« Reply #1 on: 17 December 2005, 14:13 »
Sounds like your battery isn't liking the cold weather mate.
Offline Tornado
« Reply #2 on: 17 December 2005, 14:29 »
Hi there
It is not the battery. The battery is new and the engine cranks over really well. However when it is really cold it takes lots of cranking and then immediately before it does start it turns over very slowly once or twice then starts. It is not the gradual slowing down that you get with a dud battery.
Regards
Alan
Lower!
Offline The Hoax
« Reply #3 on: 17 December 2005, 15:49 »
Alan
My 16 valve does this occasionally but not when its cold - it is when it is particularly hot. Try a combination of not touching the throttle, half throttle and full throttle. My hot car prefers full throttle.
Cheers big ears
Offline the Driver
  • smell it
« Reply #4 on: 17 December 2005, 16:13 »
had the same problem with my 8v digi , i fixed it by replaceing 18 year old leads , and , 1st turn everytime it starts
Blah blah blah Angledust
Offline Tornado
« Reply #5 on: 17 December 2005, 16:20 »
Sorry guys
Should have said that I have replaced,PCV gasket, leads, dizzy cap, rotor arm, battery and have cleaned ISV and thottle body. Next i am going to replace the blue temp sender and if that fails its off to a specialist because i am a tad clueless about cars esp electrics.
I just was wondering what other peoples experiences were with cold start problems and the type of solutions they have found in case it gives me clue to my problem
Kind regards
Alan
Lower!
Offline Organisys
  • Old and Slow...
« Reply #6 on: 17 December 2005, 16:26 »
yep, try blue temp sender. 5 min job. get from GSF.
 :santa:
