Author Topic: Ignition module??  (Read 934 times)
Offline SI_GTI
Ignition module??
« on: 15 December 2005, 22:19 »
went out to my car tday and it basically wont start :sad:
but this is an intermittant fault.usaully i give it half hour n its
fine however tday is not so.but i have been told its a possibility thats
its the ignition module as this is a common prob???
Re: Ignition module??
« Reply #1 on: 16 December 2005, 13:44 »
Good place to start, how new is the dizzy cap, rotor arm & plugs?  It could also be a problem with the hall sender in the dizzy.
Could you tell us exactly what the symptoms are, and what car it is ;)
Offline SI_GTI
« Reply #2 on: 16 December 2005, 23:04 »
sorry its a 1.8 8v '90 gti and basically it wont start.last week it was intermittant but now it
wont do anything. :sad:
Offline Mr Blue
« Reply #3 on: 16 December 2005, 23:09 »
check all earths. does the fuel pump prime with ignition on.
doubt it will be the ignition mod but i have a few spare if need any :smiley:
Offline SI_GTI
« Reply #4 on: 17 December 2005, 23:11 »
everything seems fine yep just wont start
Offline heemoth
« Reply #5 on: 21 December 2005, 13:05 »
Does it turn over and not start or does it not turn over at all?
Mine wouldn't turn over occasionally and it was a loose connection onto the starter motor, unclipped it and bent it closed with the pliers so it gets good contact.
« Reply #6 on: 21 December 2005, 13:33 »
Does it just do nothing when you turn the key?  If so this is exactly what mine did when my earth lead was loose!  Take all the battery +ve & -ve plus the alternator leads off and give em a good clean with a wire brush & refit ;)
