Golf mk2
immobiliser, how does it work?
Topic: immobiliser, how does it work? (Read 1273 times)
Haribo!
15 December 2005, 20:00 »
mines a 90 spec driver the immobiliser is a square box at the front by the drivers side wing, i can turn it on with a key and then my car wont start, brillient, but how the hell do i operate it properly without poppig the bonnet to turn it on and off??? i have a little red flashing light thing on my dash and also a little pad with a button that lights another up when i press it so im assuming that its that that i use but how and when and where?? it all seems to work but not together as they should, im dead confused? anyone got the same set up know how it works???
Last Edit: 16 December 2005, 15:37 by Haribo
Haribo!
Re: immobiliser, how does i work?
16 December 2005, 04:23 »
odd, i was out fiddling with it in the hope it would start working and it did actually work .... once, the little red light lit up nice and bright and when i pressed the little button on my keyring the car made an odd noise then my lights flashed then my alarm made a noise then i could start my engine, then when i turned it off again it stopped working again, im not sure what to check , the little red light does light up but very faintly and nothing happens when i press my keyring now..
now im REALLY confused
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
16 December 2005, 13:43 »
Try replacing the battery in the keyring
Haribo!
16 December 2005, 13:52 »
nah im sure the keyrings ok cause it al lights up nice and bright and worked for the short time that the dash light worked, but the little red light on the dash is faint, i thought it might be a fuse but then it wouldnt work at all would it? its very annoying
rubjonny
10k hero
16 December 2005, 13:59 »
Doesn't mean its working though, my girlfriends spare alarm keyfob lights up nice n bright, but wont actually turn the alarm off. Swap a new battery in and it works
Haribo!
16 December 2005, 14:09 »
hmm ok well ill do that,where am i to get such a battery???
Haribo!
Reply #6 on:
16 December 2005, 14:46 »
just got a new battery, no change, still doesnt work, i think that the light on the dash isnt geting the power it needs, why might that be? it worked for a few seconds last night , i dont get why it would do that........
rubjonny
10k hero
Reply #7 on:
16 December 2005, 15:00 »
hmm, could be a loose earth somewhere? Take the dash undertray off and have a look at the wiring under there, might be worth taking out the dash clock surround too
Haribo!
Reply #8 on:
16 December 2005, 15:33 »
took off the undertray and followed to two wires coming off the light, the brown one eventually links up to an odd black box sitting behing my dash on a ledge, and the grey one goes to a red plastic thing and off that comes a purple cable that goes to another red plastic thing and then another purple cable disapears off further than i can see
Golf mk2
