Author Topic: loud exhaust(not leaking or broken)  (Read 1507 times)
Offline monkeyboyroy
« on: 14 December 2005, 18:02 »
im running around in a 87-88 mk2 gti 8 valve, the exhaust is sounds really meaty but looks normal, it has 2 pipes at the back.
any idea's?
Offline Mr Blue
Re: loud exhaust(not leaking or broken)
« Reply #1 on: 14 December 2005, 18:23 »
run the engine.
go to the back and cover the exhaust holes with your hands (use gloves if your gay :grin:)
now listen for any air leaks in the exhaust system :smug:
« Last Edit: 14 December 2005, 18:25 by Mr Blue »
Offline hc-animal
« Reply #2 on: 14 December 2005, 18:35 »
could be the baffles in the rear box dislodged, does it rattle?
« Reply #3 on: 14 December 2005, 19:53 »
nah, no leak, no rattle. no glove :grin: :grin:
Offline Volkswagavin
« Reply #4 on: 15 December 2005, 09:59 »
Could be that someone had set the timing wrong.  Mine, unbeknownst to me was set at idle when it should have been set at 2500rpm.  When it was put right the exhaust suddenly became quiet and bearable!  It also gained a lot more power and became much easier to drive.  It also gained about 8mpg around the streets.
If its an early digifant engine you have, its worth checking.
Gav
Mk2 Golf GTI 8v - J reg
« Reply #5 on: 15 December 2005, 15:03 »
all sorts of problems!!!!!!!!!!!!!!!!!!!!! found a leak round exit of middle box :huh: idle is too high, wont go below 1800 when hot, 1100 when first started. chicken and egg situation :laugh: :laugh: where do i put that rag soaked in petrol..................... :laugh: for sale: golf shaped barbie'que................
Offline SI_GTI
« Reply #6 on: 15 December 2005, 22:14 »
mine is dead loud as well,and its runnin like a bag a sh!t :sad:
Offline bulk66
  • Im broke an it aint a joke!!!!
« Reply #7 on: 15 December 2005, 22:21 »
My exhaust is quiet loud when stood on drive and its not bust or any thing. My timing might be out a bit to but seems to run ok, Time to go and get it on a rolling road i think!!  :rolleyes:
« Last Edit: 15 December 2005, 22:24 by bulk66 »
« Reply #8 on: 16 December 2005, 12:12 »
about to turn mine into a fish tank..... :laugh:...........time to remove the bypass valves to get the heater workin:laugh:.......hmmmm.......put the wellies on its bound to blow the matrix, do i take the blue or red pill, feck ill take both! :grin:
« Reply #9 on: 16 December 2005, 21:18 »
put some gun gum round exit pipe :smug:..............quieter!! still running poo but its still fast too :grin: :grin:
