Author Topic: clicking noise?  (Read 5611 times)
Offline GTI NZ
Re:clicking noise?
« Reply #10 on: 07 November 2003, 01:06 »
definatly, packed them with as much grease as possible, what a meesy job it was.
I think i've found the noise, i took the caps of the suspension top mounts, and i can hear the clicking, there is also a bit of movement, so i'll get on to that wen i get sum spare time
Blue MK2
Re:clicking noise?
« Reply #11 on: 07 November 2003, 10:06 »
You must not have standard suspension as it makes that 'click'  noise?
Happend to me when i put on coilovers. Only cured it last week after 5 months.
« Last Edit: 07 November 2003, 10:09 by Blue MK2 »
golfvr6
Re:clicking noise?
« Reply #12 on: 08 November 2003, 00:04 »
Jack the car up so the suspension is on full hang , then try and rattle the spring, if there is any free play you will hear a clicking noise.
Offline GTI NZ
Re:clicking noise?
« Reply #13 on: 09 November 2003, 07:32 »
How would i go abouts inserting the washer in the suspension top mount to prevent that annoying sound?
thanks
Blue MK2
Re:clicking noise?
« Reply #14 on: 09 November 2003, 11:22 »
You have to take the whole suspension out.
I put one 4mm washer on the underside of the topmount. The suspension then pushes up on the washer. You with me?
Once you take the suspension out it should be more clear.
Any questions let us know
« Last Edit: 09 November 2003, 11:23 by Blue MK2 »
Offline GTI NZ
Re:clicking noise?
« Reply #15 on: 10 November 2003, 04:18 »
ok so i have to undo the bolt up the top on the strut tower, and the two bolts down below that are above the brakes in order for the shock absorber to come out?
Or the springs and shocks have to come out so the whole strut comes out which involves making sure that side of the car is suspended on a jack?
Thanks for your help Blue MK2
Blue MK2
Re:clicking noise?
« Reply #16 on: 10 November 2003, 11:45 »
With the car on the ground you should undo the top bolt first.
Then jack the car up and undo the bottom 2 bolts near the brakes. The suspension should come out now with the top mount attached.
The top mount requires a special tool to undo the special bolt and an allen key is is also required.
Offline GTI NZ
Re:clicking noise?
« Reply #17 on: 11 November 2003, 00:09 »
ok i'm with ya now, i guess this will take a couple of hours work, at first i thought i just had to remove the bolt up the top.  ::)
thanks a bunch Blue MK2
