depends which k04. the k04-001 would see you about 235bhp, and you can keep the standard feeds to the turbo. a front mounted intercooler would be beneficial but not necessary. at that kind of power you would want it breathing better so an uprated downpipe + cat (milltek do one to suit your cat-back system) would be needed... you might want to consider upgrading the brakes/suspension too. you could get the same from a k03s turbo which you can probably pick up a lot cheaper.
if you want the k04 from an S3/TT then its a whole different ball game. 260-170 bhp but you need the manifold, injectors, oil feed lines, custom downpipe etc etc..
either option would require a custom remap. to be honest though i'd suggest you have a go in a stock turbo car that has been remapped, you'll probably find its quicker than you'd imagine... add the downpipe/hi-flow cat to your current mods and get it remapped im pretty certain you'll be happy with the power. the way the new map affects the way the turbo spools means you get huuuuge low down torque even from the standard turbo.. wheelspin city !
Couldn't agree more!!! I had my re-map from Jabbasport on a completely standard 150 bhp AGU, & now sit pretty with 202 horses
Wheelspin is a nightmare in the wet..... Improves your throttle control, though!
My 2 front Eagle F1's (new in May), have now only got about 3.5mm left!
Torque & power is now unbelievable.
I agree with Topher, re-map what you've got now (maybe get the downpipe/cat if you're feeling flush - No need, IMO). I don't think you'll be disappointed.
I can even pull away from Civic Type R's (albeit fractionally) now.... Never a chance, beforehand.
My mate in his 306 Gti-6 used to pull away from me.... Not anymore, though!
