Author Topic: noise from front wheel area...  (Read 2191 times)
Blue MK2
« on: 05 November 2003, 20:32 »
When i turn i get a noise that goes like this...''tik', 'tik', 'tik' and increases depending on the speed im doing. This happens more on the left hand side but i dont even put it on full lock.
It doesnt rub on the inside by the wheels and im running on 15"s with 195.45/15 tires.
any clues mates as this only happens when im doing a tight turn but not on full lock?
golfvr6
Re:noise from front wheel area...
« Reply #1 on: 05 November 2003, 20:37 »
Sounds like the outer cv joint, does it get worst on full lock?
kniterider
« Reply #2 on: 05 November 2003, 21:25 »
yep sounds like a cv joint
Blue MK2
« Reply #3 on: 05 November 2003, 22:10 »
I was thinking of the CV joint, thanx im now certain it is that and yes it gets worse on full lock
golfvr6
« Reply #4 on: 07 November 2003, 00:18 »
Cut the clip on the boot, pull it back and make sure there is plenty of cv grease in there (or moly grease).
Blue MK2
« Reply #5 on: 07 November 2003, 09:57 »
yeah there is loads of grease. I also put more grease in it.
