Author Topic: rear brakes  (Read 701 times)
Offline theviper
rear brakes
« on: 08 December 2005, 22:20 »
thinking of upgrading the rear brakes i can only think of 2 ways of doing it
1 change the whole axle from a MK2 16 Valve
2 put the Disc conversion kit on
which one is the best one to do ?????
Pete  :evil:
Offline AudiA8Quattro
Re: rear brakes
« Reply #1 on: 09 December 2005, 00:27 »
Don't bother.
Rear brakes do very little anyway, just make sure they are set up properly.
Re: rear brakes
« Reply #2 on: 09 December 2005, 10:47 »
The only thing worth doing is replacing the whole beam with one from a GTI as they have a built in ARB, and if you do so make sure you fit nice stiff poly beam bushes & braided brake hoses all round.
If you do this you'll need to fit a front ARB to match ideally, but if you have a 1.8 Driver or GL you should already have one ;)
As golfvr6-is-back says doing the brakes on their own isn't worth it as you wont notice much if any extra braking performance.  You're better off fitting GTI discs & pads on the front :)
« Last Edit: 09 December 2005, 10:49 by rubjonny »
