aye just make sure you give the motor a serious oiling/wd40 when you go to replace the resistor otherwise you'll be replacing it again about 2mths down the line!
the reason the motor tightens is because water seeps down under the scuttle tray and into the heater housing. so give the housing a bit of a seal with silicone or similar
GSF stock the resistor packs also, if you cant be bothered soldering the new fuse in!
