Author Topic: my 8v not starting up  (Read 3576 times)
Offline raj
« on: 05 November 2003, 14:46 »
my 8v gti is not firing up. i cheaked the leads,sparks plugs and the distributor and all seem to work fine the is fuel getting in to the engine. i have cheaked the timing aswell that all seems fine. how ever i did change the hosing joint for the water pipe. can anyone help plz!
Offline richandhazel
Re:my 8v not starting up
« Reply #1 on: 05 November 2003, 15:22 »
Have you checked that you're getting a spark at the sparkplug?
Can't see how changing the water pipe housing joint would have caused the car not to start.........unless you disturbed something else.  :-\
Offline raj
« Reply #2 on: 05 November 2003, 18:12 »
yeah i am getting a spark from all plugs and coil. it turns over but not firing. it very unsual.
Blue MK2
« Reply #3 on: 06 November 2003, 08:43 »
I had that problem and my car was off the road for 3 weeks.
It turned out to be that thing on the starter motor. not sure what its called. (Its stuck to the starter motor)
Anyway it caught fire.
I was told if that part fails then it will not send a signal to the ECU and basicaly the car wont start.
??? Worth a look
Singh
Offline COCKEL
« Reply #4 on: 06 November 2003, 16:19 »
GIVE YA FUEL PUMP RELAY A POKE...THEY SOMETIMES HAVE PROBLEM THERE, MINE DID.
YOU MIGHT SMELL FUEL BUT CAN YOU HEAR THE PUMP HUM....
LET ME KNOW HOW YOU GET ON... ;)
Offline raj
« Reply #5 on: 06 November 2003, 20:56 »
yeah i been told that there is not alot of compression in the engine that y it aint firing up
Offline COCKEL
« Reply #6 on: 06 November 2003, 21:57 »
THAT SOUNDS LIKE BOLLOX TO ME RAJ...WHOS YA MECHANIC MICKY MOUSE. ;)
SO IS IT BETTER TO HAVE NO COMPRESSION?
SO IT TURNS OVER ...IT HAS A SPARK..AND YOUR GETTING FUEL....HMMM
GOOD LUCK ;D ;D ;D
Blue MK2
« Reply #7 on: 06 November 2003, 21:59 »
Cockel,
wheres the starter relay, is this in the fuse box area or on the starter motor?
Offline COCKEL
« Reply #8 on: 06 November 2003, 22:09 »
FUSE BOX MATE JUST GIVE IT A PROD IF THE PUMP DONT  HUMMM...ITS A SILVER ONE I THINK... :)
ITS A SOLINOID ON THE STARTER GEEZ!!!!
« Last Edit: 06 November 2003, 22:12 by COCKEL »
Blue MK2
« Reply #9 on: 06 November 2003, 22:19 »
safe
