Author Topic: wheel ET  (Read 2810 times)
Offline jax
wheel ET
« on: 09 June 2003, 20:30 »
im (hopefully) buying some brock b1s in a 7.5 x 16 size and was wondering what difference the ET would make and what ET i should go for on a mk2 driver lowered 40mm: 25 or 35?
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Judderi
Re:wheel ET
« Reply #1 on: 03 July 2003, 11:09 »
Dunno try phoning home!
Offline jax
Re:wheel ET
« Reply #2 on: 06 July 2003, 13:53 »
lol
Offline black_vr6
Re:wheel ET
« Reply #3 on: 06 July 2003, 22:36 »
hi there
i used to have a mk2 16valve i discovered that by putting on an ET45, which is actually a vauxhall offset,i was able to drop the car right down with out  any major problems.i was running on 17 / 7.5 wide stil auto,s. a lot of  vw drivers always wondered how i got my  car so low without scobing.by using the ET45 offset there is virtually no clearance on the inside of the tyre and the rear subframe,but u can get away with it.However u need to be sure that the 16valve doesn,t use wider or different  size hubs than a driver.let me know how u get on m8
