Author Topic: battery confusion, help  (Read 1045 times)
Offline gc350
« on: 06 December 2005, 22:52 »
Hi, please bear with me on this one.
I have got a new battery to go on my Mk2 Golf Gti 8v (1985)
It is as follows:- Exide W065SE.  50A/Hr    495 CCA
The exide website also shows (for the same car) a W065TE which is 55A/Hr    600 CCA
I have just looked at the one in my car and its spec is 55A/Hr     480 CCA
Will the new battery (Exide W065SE.  50A/Hr    495 CCA) be good enough, and strong enough?
I dont even know what one should be in there (don't have a manual or nout).
Offline Mr Blue
Re: battery confusion, help
« Reply #1 on: 06 December 2005, 23:35 »
If it cranks the engine it should do  :tongue: :wink:
Offline *Dubby*
« Reply #2 on: 06 December 2005, 23:36 »
I had the wrong battery on my golf for ages  :laugh: it worked. Thafe.
Jeeeeeeeeeeeeeeeeeeeeeeeeep
Judderi
« Reply #3 on: 07 December 2005, 09:08 »
CCA means Cold Cranking Amps. The higher the rating the stronger the battery you could say. Should be fine with y new one if not a little better.
