Author Topic: mk2 lowering suspension questions?  (Read 2050 times)
Offline GolfGTiMk216LoveIT
« on: 06 December 2005, 17:41 »
i wanna lower my mk2 valver i have a set of 6.5 x15 bbs splits(no tyres yet) and i was wondering wot kinda of drop i should be looking to get on them and what kit would be best. im thinkin between 40-60mm but i am told that my car is 30mm lower than standard golfs so will this affect it. also when lowering are there any other things reccomended to be changed cheers :undecided: :laugh:
Offline *Dubby*
Re: mk2 lowering suspension questions?
« Reply #1 on: 06 December 2005, 22:50 »
my mk2 was dropped 40mm. 15" alloys on 45mm profile tyres went on ok without scrubbing.
while youve got it apart, i would change the top mounts - these are prolly less than a tenner from Euro Car Parts  :smiley:
Jeeeeeeeeeeeeeeeeeeeeeeeeep
Offline shaft69
« Reply #2 on: 06 December 2005, 23:05 »
Well mine's dropped 60mm on spax psx adjustables and i love them. For me thought front was wee bit too high so used bonrath lowering caps (jom ones are sh!t) Thats brings it to -70mm on front. spot on drive, Cant fault it. have used many other kits before this is the best so far. Depends on what you want, If you want non adj then sprintline bilsteins (yellow ones) poss best you can get. never used coilovers so cant recommend, But my mate uses bilstein coils pss9 on has mk3 says they are the dogs, But very exspensive. By the way using 7jx15 BBS et24 with 195/50 no scrubbing.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline 16valve
« Reply #3 on: 07 December 2005, 18:27 »
Maybe worth new wishbones and adding poly bushes I also bought bump stops and ball joints as they need doing, and definitely front top mounts as already mentioned, I'm going to be removing my rear shocks again and fitting new rear top mounts as I have an annoying rattle only small but I'm so fussy :rolleyes: and I will be changing the rear axle bushes as they need doing and its got to be one or another  :grin: so maybe worth considering all bushes depending on mileage?
I've only gone -40 Konis on standard 15" Ra's and really needs another -10 IMO will be putting my 16's on in the new year after the bloody gritter has retired for another year and hopefully will bring the wheel closer to the arch!! :laugh:
Offline GolfChick24
« Reply #4 on: 07 December 2005, 23:21 »
well having recently lowered mine by 40mm by meself on me drive the small bit of advice i can give is get ready to get new bump stops as both mine on either rear side were totally knackered and split in two, and also get ready to be screaming at it!  :grin:
I have fk dampers and springs all round, bought from a guy on ebay for bargain price of £150 brand new and hes from errr austria or belgium and they're brand new. At first i was a bit disappointed but having now been to demon tweaks and got the camber, castor and tracking all checked and adjusted and now the suspension is actually softening up Im really pleased with it. Handles a lot better you dont have that major tilt on corners and just feels more sollid.
The fact your car is 30mm lower already shouldnt play a factor cause you're replacing everything but in terms of looks wise, if you go for 40mm its only gonna be cms difference looks wise but obv newer kit. If that makes sense.
if you're doing it yourself you'll need those magic spring compressor efforts or boing!!!!  :grin:
