Author Topic: heater problem  (Read 3089 times)
Offline raj
heater problem
« on: 05 November 2003, 01:16 »
i have a mk2 8v GTi, my problem is my car does not blow out hot air only cold. i have cheaked my matrix not leaking. can anyone hepl?
Offline Gambit
Re:heater problem
« Reply #1 on: 05 November 2003, 09:25 »
aye, you've probably got an airlock
make sure your heater setting are set to max heat.
flush the system
refill it
let the car idle with the expansion cap off until the fan kicks in or the water boils
turn the engine off, top up the coolant level and stick the cap back on tight
Offline raj
Re:heater problem
« Reply #2 on: 05 November 2003, 14:34 »
cheers mate!
Offline richandhazel
Re:heater problem
« Reply #3 on: 05 November 2003, 15:50 »
Could be an airlock as 'Gambit' suggests. The other thing worth checking is your bypass valve. There's been a few threads recently concerning poor Mk2 heaters where this has come up.
Offline willy368
Re:heater problem
« Reply #4 on: 05 November 2003, 22:31 »
Raj,  Listen to a bloke who knows,  in front of the heater matrix in the engine bay are the two rubber tubes which come from the bulk head.  Attached to the tubes is a small alluminium type 3 way valve,  go to a scrappy, or indeed to VW and buy one of these small devices.  Replace your valve with the "new" one and your problem should go away.  To give you a bit of history, last year I replace my heater matrix when I had the same problem as you, nightmare job working upside down arms all scratched to pieces.  When I finished the job the heater was still cold.  ?2.50 from a scrappy for the new valve..... Car was Roasty Toasty.  Let me know how you get on. ;)
Re:heater problem
« Reply #5 on: 06 November 2003, 02:06 »
Yep, we're both talking about the same thing, bypass valve, 3 way valve........worth looking at.
Blue MK2
Re:heater problem
« Reply #6 on: 06 November 2003, 08:36 »
I dont have one. You recon i should get one on my 8v?
Do you install a valve on both tubes that go into the bulkhead?
Offline raj
Re:heater problem
« Reply #7 on: 06 November 2003, 10:59 »
thanx everyone for your advice much appreciated
