Author Topic: Tyres for Golf Mk2 16V  (Read 21721 times)
Offline msond
« on: 05 June 2003, 19:28 »
I need to chage the tyres on my Mk2 16V. They are currently 185/55/15.
Would it make much difference if I changed the size to 195/50/15 as the are quite cheaper than the equivalent 185/55/15 make of tyre?
Any suggestions on what make of tyre to go for?
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Current - Mk 7.5 GTD with sunroof, keyless, Dynaudio, Pronav, , reverse camera, Art Velours trim and self park.
Previous -
Mk 7 GTD. Tornado red with Santiago wheels, Pro sat nav, keyless and winter pack.
Mk 6 Golf GT. Reflex silver, heated black leather, 18" Vancouver wheels, climate control, RCD 510 with DAB, Bluetooth, parking sensors, luxury & storage packs.
Mk 3 Golf GTi 8v Anniversary
Mk 2 16V
Offline Jon16
Re: Tyres for Golf Mk2 16V
« Reply #1 on: 06 June 2003, 00:19 »
I have a 16v too on 15" BBS and it runs great on 195/50/15.  I'm pretty sure the tyre size you have is original, but as you say expensive.  The rolling diameter of your wheels will be slightly different, but not so as you notice (fractionally incorrect speedo? on 50 profile).  Lower proflie and slightly wider tyres should improve cornering slightly.  Only thing is I'd try not to mix sizes on the car and deffinitely not on the same axle.
lee
« Reply #2 on: 06 June 2003, 01:59 »
Hello John16
Just thought I would ask what tyre pressure's you are running with those 195's. The reason I ask is because I have the same size and they always look half flat.
Offline Jon16
« Reply #3 on: 06 June 2003, 19:53 »
Unless the car is loaded up I use the same pressures as recommended inside the fuel filler cap (although I admit these are for the 185/55/15s).  Pretty sure this is 2.2 bar front and 2 bar rear.  At these pressures, the car is generally used 1 or 2 up with little luggage.
Offline modulater
« Reply #4 on: 07 June 2003, 00:21 »
I recently had to replace my Pirelli P6000's on my golf 16V and got quotes of ?90 quid each wheel to get them done but I thought that was expensive so looked on the internet, I came across a site that sells top brand tyres cheaper and managed to get the Pirelli's for ?53 quid each, my local tyre centre fitted and balanced them for free as I take the work vans in there. The site if your interested is www.mytyres.net
lee
« Reply #5 on: 07 June 2003, 14:51 »
Hello
If anyone out there has a car shop near them called INCAR ,they sell avon fzero 195-50-15s for ?29.99 each. You cant beat that. There is one in croydon and one in sutton surrey.
Offline msond
« Reply #6 on: 10 June 2003, 19:45 »
Thanks for your help.
I think i'm going to stick to 185/55/15 tyres.
Previous -
Mk 2 16V
