Author Topic: Passenger floor leak  (Read 766 times)
Offline JB G60
« on: 05 December 2005, 10:15 »
Hi,
Just got my G60 home and after driving it in the wet a bit I realised the passenger floor was completely soaking, I have taken off the wheel and there is no sign of any holes. Is this common on the mk2's or is there something going on?
Thanks in advance,
Jack
Offline Steve_B
Re: Passenger floor leak
« Reply #1 on: 05 December 2005, 17:27 »
I've had this problem before. Under the grill at the top of the bonnet, near base of the windscreen, there is a run-off channel that leads out to above the wheel arches on both sides. You need to check that there is no gunk blocking where the water runs out.
Offline takethefifth
« Reply #2 on: 05 December 2005, 19:32 »
You could of course have a read of this thread.....   "Moister than moist! please help!" I put a link to it but it changed.... hmmm.  Its a current thread so should be on this main page.
And also searching as i remember a few threads on this problem that will be around somewhere.
« Last Edit: 06 December 2005, 00:04 by tt5th »
