Hi All.
Been having fun & games with my GTI recently so I thought I'd share the pain...
Started a couple of weeks ago on my 97 8v 2L GTI (AGG engine) when it kept stalling when I took my foot off the accelerator.
Having had problems in the past with a mk2 I cleaned all the breather pipes, & broke the breather valve/bung on top of the rocker cover (DOH, £40 from vw!!!), checked the plugs/leads(sparks ok)/dizzy cap & rotor arm.
Still no luck, so I popped it into the local mechanic (good, honest type) who told me that a couple of wires had shorted out on an exposed part of the clutch cable which in turn blew the coil..... (check that all your wiring is in good conditon & cable-tied out of the way folks!)
All the affected wiring & coil have been replaced but still wont tick over. So now the ECU has been sent away for testing.
If faultly, it's gonna be painfully! ÂÂÂ
Will let you all know how it goes.
