Author Topic: Heater motor replacment URGENT PEEPS!  (Read 2203 times)
Blue MK2
« on: 04 November 2003, 18:37 »
Does anyone know how to get the heater motor out?
Its located under the dash on the left. Its faulty and winter is kicking in big time!
Ive tried to unclip the clips i can reach but it still dont wanna come out?
Can someone tell me step by step how to take it out plz..
Cheers this website is very handy!
golfvr6
Re:Heater motor replacment URGENT PEEPS!
« Reply #1 on: 04 November 2003, 18:40 »
I think once you have undone the clips, you simply have to rotate the motor unit to remove it. Whats wrong with it?
Blue MK2
« Reply #2 on: 04 November 2003, 18:45 »
WOOW THAT WAS A FAST REPLY! :D
When I tap the motor it slowly turns. This happens on every speed.
It sometimes doesnt work at all and im thinking it needs greasing.
What does a resistor do? Could that be the problem?
golfvr6
« Reply #3 on: 04 November 2003, 19:09 »
All the resistor does is allow the motor to run at different speeds, when it packs up the motor will only work on full speed.
Offline tinman
« Reply #4 on: 04 November 2003, 19:23 »
Cheap way of replacing it - find someone with a smacked Golf and offer them a fiver for it.
Works every time.
Tin
Blue MK2
« Reply #5 on: 04 November 2003, 22:47 »
Under the motor is a large 'O' shaped cover. how do i take this off?
kniterider
« Reply #6 on: 04 November 2003, 23:02 »
get one from a breaker if youve got probs, only a cheap fix but will do the trick, min kept blowing 30amp fuses, kleened the lod girl crossed some wire over the fuse and shes fine! lol
gaz
Offline Gambit
« Reply #7 on: 05 November 2003, 11:01 »
did you get it off?
there is one clip at the back of it, you need to get a flat head screwdriver and push it up otherwise its impossible to rotate the motor anti-clockwise to remove it
just have a feel of it, or else get a torch & look at it.
its a piece of piss once you see the clip.
mine use to rumble cause of a knackered bearing, so i just went to the scrappy and pinched one
Blue MK2
« Reply #8 on: 05 November 2003, 22:32 »
Ohh taking it out is too easy. Sorted the heater by taking it to bits.
There was a spring that was held in place by a metal clip and it was dirty causing the motor to flicker on and off.
 ;D
« Last Edit: 06 November 2003, 17:27 by Blue MK2 »
