Author Topic: VR6 BOX ON A 16v Mk2  (Read 1939 times)
Offline HARDCOR3
« on: 02 December 2005, 13:30 »
VR6 G/box, does it fit on a Mk2 16v?????? :huh:
mix
Re: VR6 BOX ON A 16v Mk2
« Reply #1 on: 02 December 2005, 13:45 »
with a big enough hammer, yes....
Offline HARDCOR3
« Reply #2 on: 02 December 2005, 15:52 »
cheers, thats a great help..... :tongue:
mix
« Reply #3 on: 02 December 2005, 16:58 »
i know :wink:
Offline Overseer
« Reply #4 on: 02 December 2005, 17:09 »
i thought mk2 16v gearboxes were significantly different from mk3 16v/mk3 vr6 ones.. ?
for example.. i know the mk3 one is often sourced when dropping a 1.8t engine into a mk2.. as the existing gearbox isnt compatible..
Offline ...joe
« Reply #5 on: 02 December 2005, 17:14 »
i thought they were the same fitment but the mk3's are cable change and hydrolic clutch which is more compatible with the 1.8t engine.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Overseer
« Reply #6 on: 02 December 2005, 17:20 »
maybe.. all i know is engine swappseys dont use the original..
and i figured if they using a mk3 one to be compatible then the mk2 one isnt compat..
which lead me to believe mk3 + mk2 ones = not the same  LOL
Offline ...joe
« Reply #7 on: 02 December 2005, 17:22 »
i'm pretty sure they are all 020 boxes as i know you can use turbo diesel mk3 boxes on a mk2. it probasbly more a gear ratio and the hydrolic clutch/cable change thing that makes it more common to use a 16v box on a 1.8t
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 02 December 2005, 17:25 »
im sure it will fit, but i remember someone telling me you need to swap the pedal box too ?
either way, why would you want a '6 box in a valver, the ratios are sh!te.
mix
« Reply #9 on: 02 December 2005, 17:29 »
not designed for speed :wink:
