Author Topic: Hall Sender  (Read 1876 times)
Offline Gambit
Hall Sender
« on: 04 November 2003, 14:02 »
How hard is it to change in a 16v??
had a look in the haynes and it says it jsut a case of removing the rotor arm & shaft, a dust cover & a screw to get at it
is it as simple as this??
also, what causes the hall sender to fail?
Offline Slim Shady
  • Thrash her like a ginger step child
Re:Hall Sender
« Reply #1 on: 04 November 2003, 16:52 »
it's connected to the dizzy
fairly str8 fwd to replace
they 'go' coz they are electronic - and semiconductors failing is not un common  8)
 - make sure it is the Halls sender that is shot and not any other part of the EIS.
follow the Haynes instructions and you shouldn't have any problems - multimeters are invaluable for this sort of fault finding.
« Last Edit: 04 November 2003, 16:53 by Slim Shady »
golfvr6
Re:Hall Sender
« Reply #2 on: 04 November 2003, 16:52 »
I think it is quite easy to change, the shaft is retained by a pin i think.
