Author Topic: intermittent electrical problem  (Read 1458 times)
Offline sss
« on: 01 December 2005, 10:43 »
I have some kind of intermittent electrical problem thatÂ’s just started tonight, please can anyone give me an idea what it might be..
The symptoms: Turned key in ignition and NO red lights showed on dash and car wouldnÂ’t turn over totally dead, lights will not work either. So I rocked the car forwards and backward in gear and all of a sudden ignition lights showed and car started up.. maybe starter motor you may think but then.. But got home and tested again, all was fine for 7+ starts and once again it did the same thing and just suddenly it all came back without me doing anything?
I have checked battery terminals and they were fine but cleaned all the same.
Is it pointing to some kind of earth strap fault? If so where can I find any straps apart from on the battery?
car stereo set station also reset themselves..
Any help with this odd problem would be greatly appreciated chaps.
Thanks
Offline Bazzer
Re: intermittent electrical problem
« Reply #1 on: 01 December 2005, 10:55 »
I'd say you're on the mark with the earth strap mate. Either that or the battery itself?
Bazzer
Offline Len
« Reply #2 on: 01 December 2005, 11:07 »
Check the main feed from battery to starter, make sure there are no shorts, then check the earth straps.
There's usually an earth strap from the gearbox.
www.sas.org.uk
www.the-ace.org.uk
Offline sss
« Reply #3 on: 01 December 2005, 13:12 »
thanks for your reply guys
