Author Topic: Bigger capacity?  (Read 2526 times)
Offline Mk1GTi1.6
Bigger capacity?
« on: 30 November 2005, 20:35 »
Hi
I'm looking for some info on getting a larger capacity engine into my Mk.1.
What are the easiest options???
thanks :cool:
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: Bigger capacity?
« Reply #1 on: 30 November 2005, 21:35 »
check out the subject we discussed before;
http://www.golfgtiforum.co.uk/index.php?topic=27461.msg220854#msg220854
Check out these sites for performance upgrades on engines for mk1's
http://www.candrenterprises.co.uk/
http://www.tsr-performance.com/
http://www.awesome-gti.co.uk/
or look here for tuning ideas
http://www.matey-matey.com/
« Last Edit: 30 November 2005, 21:37 by Madone »
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline Lewy
« Reply #2 on: 30 November 2005, 22:29 »
Don't listen to him - he's freakin' fruit loop :laugh:
Seriously though, Simon is a very good source of info for mk1's, even certain powerplanted mk1's!! :lipsrsealed:
Offline Madone_si
« Reply #3 on: 30 November 2005, 22:50 »
This is a very useful Mk1 info web page - http://forums.vwvortex.com/zerothread?id=594424
SOLD - BLACK SOY 92
Offline Mk1GTi1.6
« Reply #4 on: 01 December 2005, 21:44 »
Cheers guys, some good links there.
Do any of the 2.0 bottom ends just bolt straight up to my 8v head?
And does anyone know anything about using the bits from a turbo diesel VW to turbo my engine?  Read a thread on vwvortex about it, but got lost half way through it!
Offline Neaty
« Reply #5 on: 02 December 2005, 15:36 »
My mate used a turbo diesel manifold on a mark 2 8valve bottom end, requires a bit of grinding but other than that i think its ok, but if you want to use a T3 turbo or something similar then it wont directly fit on the manifold. Keep you eye out on ebay for turbo technics manifolds
Offline Mk1GTi1.6
« Reply #6 on: 02 December 2005, 17:40 »
Sounds like a top tip.  Cheers.   :cool:
Offline Mk1GTi1.6
« Reply #7 on: 03 December 2005, 12:26 »
Was also reading that you can mate the compressor housing of an Audi or Saab petrol turbo, to the other half of the TD turbo.  So it fits to the manifold but gives better power further up the rev range.
As with all these things, I guess it's a case of trial and error!
Offline Neaty
« Reply #8 on: 03 December 2005, 16:21 »
definately. home bad turbo conversions are all like that, my mate made his own manifiold byt chopping and welding an 8 valve manifold, it worked but then the oil seals on the turbo went and had oil pi**in out every where. Everyone has there own ideas all u can do is try them, no harm in that
