Author Topic: ABS sensor price  (Read 2285 times)
Offline monkeyalan
ABS sensor price
« on: 30 November 2005, 19:24 »
ABS light been coming on intermittantley for a few days and the pedal has kicked at low speed a few times . From other posts,  i assume it's the ABS sensors? Checked ECP for prices and got the below
http://www.eurocarparts.com/ecommerce/Search_Results.asp
as you can see they only seem to stock fronts , but why the variation in price? can that be right £8 and £6?
cheers folks  :wink:
Offline AudiA8Quattro
Re: ABS sensor price
« Reply #1 on: 30 November 2005, 19:49 »
Unplug the sensors and check for resistance.
Front connections are mounted on the suspension strut, rear connections are under the back seats.
« Reply #2 on: 30 November 2005, 19:52 »
Also you can try cleaning the sensors, and check the rotors for physical damage.
Offline monkeyalan
« Reply #3 on: 01 December 2005, 14:27 »
cheers dude
Offline monkeyalan
« Reply #4 on: 07 December 2005, 18:14 »
fault code finder says it's the main abs valve  :sad: does that mean the (£450  :shocked: ) abs pump?
Offline yellowgti
« Reply #5 on: 07 December 2005, 18:52 »
ive just had to buy 2 new rear abs sensors for the gti and its just cost me £55 each side and i apparently got them cheap!, if i cant fit em myself the local vdub guys, www.stokevwspares.co.uk  said they will fit em for £25 each side, main dealer £75 each plus vat and main dealer fitting £50 each side
i got the bits from www.volksmine.co.uk they are my local guys in stoke on trent
"Some say he has a brain made out of fish and that he has no drivers licence at all, all we know is he's called The-Stig"
Offline monkeyalan
« Reply #6 on: 07 December 2005, 18:58 »
i'll be happy if it's anything but the abs pump or ecu tbh.
Offline adyh
« Reply #7 on: 08 December 2005, 10:05 »
Easy to fit , just trickey to get your head round at first [cos you cant see what you are doing].
Lift up your back seat , there will be two rubber plugs with cables coming out of them going to two white plastic connectors [one for each side]. Unplug these and push the plugs through the bottom of the floorpan [i.e. outside] .
Now you should see where the wire routes along the top of the rear suspension arm and into the rear side of the brake assembly . It just held in with a allen bolt , but may be trickey to remove [they come straight out ].
Offline yellowgti
« Reply #8 on: 08 December 2005, 11:00 »
il get it up on the ramps in a bit then and have a look, cheers
