Author Topic: Mk 3 8 Valve Gearbox problem  (Read 1982 times)
Offline Monkey matt
« on: 28 November 2005, 17:30 »
I have a 1993 Mk3 8v with a crunching noise when changing into 2nd gear going up or down the box. It only does it when the engine is cold IE oil temperature showing less than 50c on the computer. Once it is over 50c it's fine. The gearbox is fine other than that. Is this a common problem?
Also the fuel consumption is very heavy in colder weather. The computer shows no more than 23mpg and the car does not get up to working temp for ages. In warmer weather 15c plus it runs at 90c water temp all day long and it returns low 30's mpg. The car is fitted with a full Magnex exhaust system with cat replacement tube and a K&N filter.
Any ideas ?
Offline Bazzer
Re: Mk 3 8 Valve Gearbox problem
« Reply #1 on: 28 November 2005, 17:41 »
Common on veedub 'boxes mate. Change the fluid and get some slick 50 in there, it'll do wonders for it....
And welcome BTW...  :smiley:
Bazzer
Offline Cra1g
  • You May Pass Me, But You Won't Outlast Me!
« Reply #2 on: 03 December 2005, 15:58 »
Bazzer, if its hard to get into gear, would you suggest new gear box oil? And whats the 50 stuff?
Cra1g
Offline Bazzer
« Reply #3 on: 03 December 2005, 20:34 »
Cra1g
Yes mate, that's what I meant by "change the fluid". 'Slick 50' is some extra slippy stuff used to protect gearboxes. You can get it in Halfrauds and places like that...
Bazzer
Offline carl
« Reply #4 on: 03 December 2005, 20:43 »
had a k&n airfilter on my car and it did crap to the gallon and failed mot
i put my vw airfilter back on and its perfect now and it passed mot ok.
Offline Bazzer
« Reply #5 on: 03 December 2005, 22:34 »
That's a fantastic story mate... But what's it got to do with gearboxes??  :huh:  :laugh:
Bazzer
Offline carl
« Reply #6 on: 04 December 2005, 00:39 »
bazzer ,
the blokes having trouble with is fuel consumption as well as his gearbox if you read it , :tongue: :tongue: :tongue:
Offline Bazzer
« Reply #7 on: 04 December 2005, 12:57 »
 :embarassed:  :smiley:
Bazzer
