Author Topic: New here... but '93 mkIII golf won't start  (Read 2047 times)
Offline savingchampy
« on: 28 November 2005, 16:54 »
 :cry:  Hello, I'm a new member in desperate need of info for my beloved car Champy, a '93 mkIII golf.  My name is Rachael, I live in London and have only had my golf for a year.  Before that I didn't drive for about four years as I could still tolerate public transport here.
I've been reading through loads of entries, but need more info on what might be wrong with the Champster.  Yes, silly name, but this car has been through the wars and is still going, hence the name.
Except, the Champ's not going right now.  I was accelerating at about 50mph in fifth, turned off the heater fan (only works on the highest setting...) and bam!  Nada.  The car cut out.  The distributor cap and rota looked blown, so I replaced them, but the car still only turns over, doesn't start.
I know a little about engine maintennance, but could really do with some suggestions.  Reading through some other posts, it seems as though it could be the relay - but as the car won't start at all, I'm just in the dark.  Thanks for any help!
« Last Edit: 28 November 2005, 17:26 by savingchampy »
Offline GolfGL
Re: New here... but '93 mkIII golf won't start
« Reply #1 on: 28 November 2005, 18:22 »
At a guess you could try testing the leads with a multimeter and looking at the spark plugs and if your dizzy looked blown then maybe your ignition coil went. could be fuel related with the pump. try the relays just over £10 each fuel and or ecu. could be something else but try posting in the garage section might get some more replies
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline Len
« Reply #2 on: 28 November 2005, 20:17 »
Hi Rachael
All of the above!
If you havent got a multimeter then as GolfGL says get some new leads then just put your plugs into them and lay them next the nearest bit of the engine and turn over to see if you got any spark at the plugs.
If not it could be the coil.
www.sas.org.uk
www.the-ace.org.uk
Offline vwagain
« Reply #3 on: 28 November 2005, 21:40 »
Hi Rachael.  To see if its the coil, remove the lead from the centre of the dissy cap and push a plug into it. Then rest it on the engine block and turn the engine over. If you get no spark, then you know its the coil that is at fault.
Cheers,
Stu
1996 2.0l 8v, black magic pearl paint<br />
Offline GolfGL
« Reply #4 on: 28 November 2005, 22:22 »
oh yeah could use ht lead testers instead of a mulitmeter, goes between plug and lead and you can see the bright spark without removing the plug should be bout £3-5 for lucas one in halfords. if you need to replace anything try AVS i think thats what there called really good prices on leads etc
