Author Topic: goin -60mm on standard shocks?  (Read 868 times)
Offline capoot
  • Mk1 Skoda Octavia VRS
« on: 28 November 2005, 10:09 »
Good idea? althou i think i have uprated shocks anyway and am not sure, what do you guys think?
Offline Agreeable Slick
  • Unit
Re: goin -60mm on standard shocks?
« Reply #1 on: 28 November 2005, 10:23 »
more than likely going to get shock absorber leaking if you use the standard ones, gt some boge gas shocks, only £40 each.
Offline Haribo!
« Reply #2 on: 28 November 2005, 10:30 »
can you do it on gti shocks? cause i fancy a bigger drop too, i knew 40 wouldnt be enuf
Offline Organisys
  • Old and Slow...
« Reply #3 on: 28 November 2005, 12:31 »
The more the drop, the greater the chance of bottoming the shock out. Also the shock is more likely to wear out more quickly, since the standard ones are not uprated like the new springs would be. Fit new bump stops too!
 :smiley:
« Last Edit: 30 November 2005, 21:32 by Organisys »
Offline Si
« Reply #4 on: 30 November 2005, 17:53 »
Mine seems fine on standard shocks. (Lowered 85mm)  with 15's.  :smiley:
I would recommend replacing to uprated shocks tho! Mine didnt like it much when i had 17's on there!  :grin:
I LOVE THE SOUND OF CARBS IN THE MORNING
