Author Topic: six speed shooter  (Read 4518 times)
Offline rickardo
six speed shooter
« on: 03 November 2003, 19:27 »
I'll give my mk4 buddies a go since the garage boffins were no help :P
A chance to get me sticky mitts on a six speeder out of a 52 plate gti turbine.
question - will it couple up to my 99 1.8 gti non turbo??
if so what effect will it have???
Offline Franko180
Re:six speed shooter
« Reply #1 on: 03 November 2003, 19:50 »
I can't comment on wether it till fit your non turbo, but I can tell you about the 6 speed. I had the 5 speed in my old 1.8t 150 and have the 6 speed in my new 1.8t 180.
I'm not so sure about the 6 speed myself. With the 5 speed I seem to remember it would do 41 in 1st, 72 in 2nd, 100 in 3rd, 120 in 4th and 140+ in 5th. Motorway cruising at 70 was about 3500 rpm I think.
But with the 6 speed they closed the ratios down, I'll have to 'test' it, but I think 1st is about 39 and 2nd is about 65 so you get less speed in gears and have to work more. Motorway cruising at 70 is about 3300 rpm I think, so I'm not sure what the advantage is, 6th is certainly not an 'overdrive' gear.
I've got a couple of mates with GTI 150 Diesels, I'm sure they said motorway cruising is much lower/quieter revs in 6th gear.
I'll check my speeds in the 6 speed again, but I'm pretty sure the speeds in the 5 speed are accurate as I've done over 170,000 in 2 different GTI 5 speeds.
Not sure if the "speed in gears' tests are the best, but there you have it, would be interested to see what other people think.
Previous - GTI 1.8T 1999, GTI 1.8T 2000
Current  - GTI 1.8T 180bhp 2003  :-)
kniterider
« Reply #2 on: 03 November 2003, 20:22 »
not sure as to wether its a straight fit, if it does fit to the block i think its a bigger clutch, then all the selector bits and bobs, ireckon you should stick with your 5 speed, ive got a non turbo, there nippy but there only 125bhp, id spend the money on a remap, miltek free flow cat and system, and a induction kit, this will take you up to around 148bhp, which aint that far of the standard 150bhp turbo! i think id buy a six speed gear knob, and spend the time thrapping 148 horses about rather than changing gear alot more times.
Offline AdamB
  • The Perfect Storm
« Reply #3 on: 03 November 2003, 20:23 »
LMFAO
I don't own this anymore - I just can't be arsed to change the picture
Offline Franko180
« Reply #4 on: 04 November 2003, 13:09 »
I did some brief tests today, but roads were so busy could only do 1st and 2nd,  haha..
1st was 39mph, 2nd was 62mph
motorway 6speed in a GTi 180
70mph in 6th 2800rpm
80mph in 6th 3200rpm
So the revs are lower at motorway speeds than in the 5 speed and for me it is a benefit due to my car having done 11,000 since June, mainly motorways! I guess the tighter 1st and 2nd ratios help with acceleration to 60, the car is certainly quicker than my previous, but thats mainly down to the  30 extra horses I would think!
I did like the 72mph in 2nd 'feature' on the old 5 speed and to be honest would have liked that gear box with a 6th overdrive gear for cruising.
Offline rickardo
« Reply #5 on: 04 November 2003, 17:50 »
cheers lads.
the box would of been a free-bee, just the cost to make it fit.
Will stick to tried and tested mods.
mucho grassy-arse (spanish footballer with no legs) ;D ;D
kniterider
« Reply #6 on: 04 November 2003, 22:46 »
hope of some help rik, would rather see the tuning options than the six speed option much more fun!
