Author Topic: golf 1.6 AEE water temp sender problem......cold start issues  (Read 1545 times)
Offline Diluxe
Hi All,
my golf struggles to start when its cold, need to keep revving it otherwise it dies , how do i check that this sender is working? is it right that thsi sender increases the fueling when its cold?
cheers
1997 16V
Offline Cra1g
  • You May Pass Me, But You Won't Outlast Me!
Re: golf 1.6 AEE water temp sender problem......cold start issues
« Reply #1 on: 23 November 2005, 23:31 »
Check things like, spark plugs, card etc...
Simple things like the moisture on the plugs or distributor cap can effect it
If I was you just do a "DIY Service"
Cra1g
Offline Diluxe
« Reply #2 on: 27 November 2005, 11:34 »
yeah done all those bits, but it struggles, two garages have told me that its either temp sender in the coolant pipe or the throttle position sensor, the TPS is about 250 quid apparently so wantto make sure its not the temp sensor.................................................
1997 16V
