Author Topic: fse boost valves  (Read 2612 times)
free
fse boost valves
« on: 03 November 2003, 13:52 »
ive got a 88 8v, and am thinking of getin one. any one got one? do they make much diffrence? are tey worth a ton? ???
« Last Edit: 06 November 2003, 09:25 by free »
Blue MK2
Re:fse boost valves
« Reply #1 on: 06 November 2003, 09:38 »
boost valves as in 'dump valves'?
free
Re:fse boost valves
« Reply #2 on: 06 November 2003, 09:48 »
no mate,,, as in power boost valves. u put in your fuel line. Aparantly the take out flat spotes and inprove touqe,,, ECT....
Blue MK2
Re:fse boost valves
« Reply #3 on: 06 November 2003, 12:44 »
ohh and they help fuel consuption? yeah then go for it mate ;)
free
Re:fse boost valves
« Reply #4 on: 06 November 2003, 13:03 »
supose 2, and they mate a sweet winein noise, but my mate has 1 on his VTS n he says it ant made ne diffrence.
Blue MK2
Re:fse boost valves
« Reply #5 on: 06 November 2003, 13:25 »
probably doesnt notice it? Does it help prevent engine ware? Its expensive for what it is.
free
Re:fse boost valves
« Reply #6 on: 06 November 2003, 13:45 »
no dont fink so, yeh it is abit pricey innit
Offline 90 red 8v
Re:fse boost valves
« Reply #7 on: 08 November 2003, 11:17 »
I think your getting 2 products confused.
The FSE biist kit is designed to increase your fuel pressure by restricting the flow back to the tank. This means that when you mash the trottle, there is lots of fuel allready at the injectors awiating to be squirted  :o, this does help iron out flat spots and makes throttle response better.
The device that makes the funny noises and is suposed to give you better MPG and power is an echo valve. I have seen several test done on rolling roads, and they have all seen a small increase in power and pick up.
So, is the FSE kit worth a ton, do you have any flat spots or slugish trottle response? only a real advantage if your engine is tuned and its setup on a rolling road.
Hope this is of some help.
craig
PS if you do fit one, make sure your fuel lines are in good shape, the extra pressure will find any weakness.
